01 TJ Sport. I’ve had this Jeep for at least 15 years. Many upgrades.
I added rear LEDs, front leds, with the flasher relay that came with them. everything has work with no problem (for years). Had to change the MFS a year ago because the fog light switch was sticking in the on position and draining the battery. Changed it, no issues. Then the turn signals stopped working, flashers were fine. Bought a new MFS and nothing worked, though I got a bad one. 2nd one and same. I noticed the #13 fuse was popped and #7 was bad. Changed both and nothing. Turned flasher on and immediately popped both fuses. I’ve checked wiring and grounds, all appear good. I replaced the MFS harness (it was falling apart) and still nothing.
One strange thing. If I put the #13 in and leave #7 out when I turn the turn signals on they light up but don’t flash. Then if I turn flashers on it pops the fuse and same time the radio shuts off and then comes back on… that’s crazy.
Any ideas?!!!
Any ideas?!!!
