I have a 6cyl 1998 wrangler 2 dr. A couple of weeks ago it drove fine. So came home from work, parked done. Following morning turned the key and it cranked the engine but didn't fire up. I cranked it for no more than five seconds then I turned it off. Then I turned the key again expecting to hear it crank and then fire...absolutely nothing. So since then I have changed out the ignition switch and put a brand new starter on 5 minutes ago. Turned the key - nothing - no crank. When I do turn the key though the dash shows all the normal lights and all the turn signals and front and rear lights work hazard switch also works. I have no idea what to do next. I really dont want to get it towed. I'd be most grateful for any advice. I did look at starter fuse and it looks normal - no evidence of any problem. Simply can't figure this out..Thanks Wayne
