Hey ya'll. New to the forum here, but, loving it so far. I'm coming to you kind folks in hopes that you can point me in the right direction. My recenet aquisition of a '98 TJ was a success! 4.0 with less than 118,000 miles, runs like a sewing machine, jam up and jelly tight. The top is in great shape but it seems as though the last owner didn't take it down very often. It was damn near impossible to get down, despite my knowing how to do it (my parents always drove Jeeps, primarily TJ's). My problem is the side pieces that "clip" into the track above the doors. I can't "flip" it out like normal. It is just sooo tight. Any suggestions on how to get these little suckers to turn loose before I break my knuckles? Also, what do you folks use for zipper lubrication? My Mom uses a bar of bees wax which she swears by. Didn't know if there was anything better on the market or???? Thanks in advance
Work done so far:
New belt
Idler
Tensioner
Heater Core flush
Thermostat
Tie rods and pitman arm
Front drive shaft (original had way too much play and was clanking around / vibrating. Decided to pull it and put in a replacement so as to not crack my case!
other than that, she is all stock (minus the wheels) and original. My Jeep guy said "you got yourself a real jewel right here".
Work done so far:
New belt
Idler
Tensioner
Heater Core flush
Thermostat
