Hey all...I am looking for a bit of advice on tire size.
I have a 1999 TJ 4.0l and am installing a mild (2" lift) and will be replacing the current 30X9.5X15 tires with something slightly larger. My offroading will be limited to mostly ice fishing and fall hunting trips on forest roads and trails. I am considering the BFG AT KO2 in a 31 or 32" and my question has to do with width. I suspect that a 10.5" will have better traction for my type of driving than and 11.5" would. What are your opinions? Am I splitting hairs here or have you seen a noticeable difference in width?
2" lift will work great for 31x10.50. If you really want to run 32x11.50, I'd suggest installing a 1" - 1.25" body lift as well. I ran 32s with 2" suspension lift and 1" body lift for many years before rebuilding for 35s. I loved that old setup.
If you do decide to install a body lift, make sure you install one that has pucks made of a rigid, non compressable material, such as aluminum or solid acetal like the ones mrblaine (Black Magic Brakes) offers.
I run 31's on my stock ravine rims, 15", JK springs up front, and a 3/4" leveler in the rear. Had to slightly adjust the turning bump stop, as the tire would rub the front sway bar on turns. Street driven LJ. It has good street manners, even on the highway. Low cost as well.
