So I have a 2006 LJ rubicon and while having some work done the idle would not always rev back down. We determined that there was a vacuum leak in the throttle body. When we dissembled it we discovered one side had some missing roller bearings making the shaft loose and destroying the shaft seals. Also made a groove in the shaft. We added o-rings and shifted the bearing accordingly however this is a temporary fix and I was hoping to find either a new oem throttle body or a service that would rebuild oem throttle bodies especially since this is a two year only model body. I’ve had no luck so plan C is to buy another used throttle body and worst case do the o rings on it. Any resource or guidance on this would be appreciated
