What are the benefits of this tune?Absolutely, if only more people would follow suit.
It's so much better to drive with this tune.
You’re doing more damage when lugging the engine. Don’t be afraid to get those revs up a bit. As previously mentioned, 3k is the sweet spot. (If equipped, don’t pay attention to that shift indicator light in the dash)I'm not looking for huge power gains. I commute to Seattle quite often and the trip is pretty much all up hill. I usually have to have the jeep in 4th gear because 5th will top out at around 45 mph. I also hate stressing the engine at 3k rpm for an hour straight. Any recommendations?
With your 5-speed and 4.0L engine, you're slightly undegeared for 35's with only a 4.56. You'd be a lot better off power-wise and likely even mpg-wise with a lower ratio like 4.88. But with your hills I personally would go 5.13. No, neither of those ratios would cause the highway rpms to be too high.I'm running 35's with 4.56 gear ratio
HP and torque are two different things... I strongly doubt a tune is going to restore the power he needs for his 35's where torque is king.15 WHP and dramatically improved throttle response and drivability.
I like their honest pricing too.Lastly, if you have a 4.0 and want to gain up to 15 WHP, invest in a FRP tune:
http://www.frptuning.com/category-s/122.htm
I have one on my TJ and this tune made an astounding difference in how my 4.0 performs.
I'm actually running with the dana 35 right now. The axles have held up pretty good actually. Its the differential that has broke on me twice already lol. The Dana 44 is too expensive for me right now. Unless there's an affordable option somewhere.With your 5-speed and 4.0L engine, you're slightly undegeared for 35's with only a 4.56. You'd be a lot better off power-wise and likely even mpg-wise with a lower ratio like 4.88. But with your hills I personally would go 5.13. No, neither of those ratios would cause the highway rpms to be too high.
I had a previous TJ running 35's, 4.0l engine and 5-speed with 4.88 gears and it was great. Since it appears you have some long steep hills in your area I would personally go with 5.13 which is a newer ratio that wasn't available when I chose 4.88.
Also, just confirming/hoping your rear axle is the optional Dana 44. The axle shafts that come in a stock Dana 35 rear axle are not strong enough for 35's.
With the correct lower ratio which would boost power to the axle, you're now even more likely to break an axle shaft which is very common with 35" tires. 35" tires and a Dana 35 are a notoriously bad combination.I'm actually running with the dana 35 right now. The axles have held up pretty good actually. Its the differential that has broke on me twice already lol. The Dana 44 is too expensive for me right now. Unless there's an affordable option somewhere.
I'm in Washington and will gladly trade you the CAI installed by the previous owner of my Jeep for your stock setup. Assuming the years are compatible of course.I'm thinking of getting this cold air intake. Would a snorkel be better. If so are there any around this price point?
https://www.quadratec.com/p/sb-filt...ifJ0YA01qyRtyVA_Phfd54vaulvYoeu8aAtX2EALw_wcB
Newb question here but what all does a tune do for you? I have an 2006 Jeep 4.0 manual 6 speed and 3” lift on 35’s that I purchased last year. I can’t get this thing to go above 60 on the highway unless I have hurricane winds behind me. I assume it’s due to the gear ratio maybe but your comment made me curious.Absolutely, if only more people would follow suit.
At what rpm do you typically shift into the next highest gear? You will get lots of people saying you should re-gear but I feel like with a manual you have a lot more control over engine RPM than with the auto. I have 35's also but with the rubicon 4.10 gears. 75 or 80 is easy. I never use 6th gear unless I am on the interstate.Newb question here but what all does a tune do for you? I have an 2006 Jeep 4.0 manual 6 speed and 3” lift on 35’s that I purchased last year. I can’t get this thing to go above 60 on the highway unless I have hurricane winds behind me. I assume it’s due to the gear ratio maybe but your comment made me curious.
Results have not been reliably confirmed with a piece of equipment with proven accuracy like this.Newb question here but what all does a tune do for you?
more sucking sounds are.....
I want to see an episode of "Street Outlaws Memphis" with you (with tune) against NashvilleTJ. I will email JJ Da Boss about setting this up. My side bet with JJ is already in.The tune on mine made a profound difference
I want to see an episode of "Street Outlaws Memphis" with you (with tune) against NashvilleTJ. I will email JJ Da Boss about setting this up. My side bet with JJ is already in.![]()
You "Elite people don't have TV" Shame on you.JJ Da Boss? Who is that?
