It all started when my 2006 TJ started acting like it had a rev-limiter at around 3200-3500 rpm. I had a code that said my cam/crank was miss aligned, I drove it like that for a while, then it started acting like it wasn’t getting enough fuel the more I pressed the accelerator. It idled fine and ran ok just easing on the pedal but when I pressed down it sounded like it’s sucking air. The harder I press the worse it is. I changed the cam sensor first, then I changed the OPD assembly. Still have the problem with no code.
I tested the fuel pressure just turning it on and also running and it’s good. Does anyone have any tips on what to do next?
Please help!!
Please help!!
