I replaced the coil rail and the spark plugs and the jeep definitely ran better, it is like it now "fires up with half a key turn and just wants to go", of course that is just a "feeling" and not a diagnostic. Anyway, drove it one day and no misfires. Drove it the second day and the check engine light starting flashing intermittently during my drive, I was doing 35mph in 4th gear just cruising, not on the throttle at all. . I could not feel any misfires, I just saw the CEL flashing. It would flash a few times and then quit and then flash a few times and quit.......... When I got home it had a P0300 pending. That was the only code Random Mis-Fire.
This morning (you got to work at night and early morning in this Memphis heat!!). I checked the wire harnesses that run to PCM, to the Cam Pos Sensor and to the Crank Pos Sensor, as well as the one that runs to the injectors and I saw no wear. I then hooked up my scanner and watched the mis-fire count and I had zero at start up, I let the engine warm up and had zero. I then started shaking and pinching the harnesses, watching the misfire count and none. I then used carb cleaner to spray around the throttle body, intake, vacuum lines, etc... and nothing. All runs good.
I was starting to think back to wheeling and I remembered that on the Windrock Trip on Thurs night when it first mis-fired it was also having a high idle. It was idling around 900-1000 RPMs in lieu of around the 600 RPMs that it normally did. It only did this for a short period of time and seemed to occur prior to the misfires starting. It never did it again the entire weekend or since then. Based on this, I again checked for vacuum leaks, but none could be found. Again, just capturing info for future reference, not sure if it means anything.
Scanner and TPS question for anyone who may know? How does the scanner bump up the RPMs with a cable throttle? My understanding is that the TPS only provides a signal to the PCM. So how does it bump up the RPMs? When I did the cam synch procedure, it definitely bumps up the RPMs to 1000 RPM during the test, so I know it does it. But when I went into the scanner and selected to actuate the RPMs to 2000 RPMs, I could here a slight change in RPM but it did not take it to 2000 RPM and it actually went down slightly? Weird?
Following. Do you think this is all related to the problems you were having intermittently in Moab? Definitely some weirdness here. I'll be happy when you put this to bed Victor.
