Suspension Question
Pullski
San Diego, CA
Can anyone ID this suspension brand? It looks pretty complicated…obviously BDS steering…but is it a BDS long arm lift?
I see the following...
Fox 2.0 remote reservoir shocks in the factory mounts.
Some brand of aftermarket rear sway bar that I can't read the name of.
An adjustable rear track bar.
1.5-2" rear coil spring spacers
A standard bolt on long arm.
Currie/RockJock CorrectLync steering
A dropped pitman arm
A dropped front track bar bracket
An adjustable front track bar
Dual steering dampers with a stupid axle bracket
Front sway bar disconnects
An aluminum radiator
There isn't anything complicated. There is a lot that is more show than function. The best pieces you have are the steering and potentially the rear sway bar.
Thanks! I’m just trying to determine if it’s gonna be a shit show to drive or replace the crap pieces!
Neither. Nothing is going to explode on you (except maybe the radiator). Use it and figure out what you like and don't like over time.
Rear sway bar looks like an older (discontinued) Teraflex sway bar system.
I don't know much about it, but had a friend that had one years ago.
Random Google pic
Reactions: jjvw and Irun
Looks like a shit show to me. Generally the second somebody cuts off the factory control arm mounts I'm out. Is there a mini cat directly under the oil pan?
I have an update…here’s a pic of the list of mods…I’m now leaning more away as it looks like I’m gonna have to be spending a ton to replace the lift…8 inches of Rusty’s Lift seems like it’s gonna be utterly useless and a nightmare on both dirt and road
Random Google pic
That is 100% the rear sway…It definitely says Teraflex on the arms…good find!
