Subwoofer not working
everetthewitt
florida
I have an 04 rubicon and it came with a blown sub, still worked but sounded like a fork in a garbage disposal. I recently got a double din replacement and have been using without the sub but today tried to replace the sub for a new quadratech one and it is not working.
Sorry I can't offer much advise, but my quadratech replacement sub was plug and play with no issues. The last thing you did was install a double din head unit. I'd check the wiring connections one more time.
Reactions: 02SteelBlue
The sub amp that came with your Tj tends to last as long as the speaker. You likely have blown the speaker and the crappy amp located right behind/next to it.
Yep, my guess is your factory shitty amp is blown too. Don’t try powering the garbage factory subwoofer with an aftermarket amp either 😉
Best to just replace it all with aftermarket stuff.
