Hi there. I have a 1998 Jeep Wrangler TJ and the speedometer is not working. The needle jumps around like crazy. I can be sitting still and it will go from 0 mpg to 130 mph and back down without ever touching the peddle. While I'm in motion it does the same thing. I have already changed the speedo gear and adjusted it to the correct ratio. I have changed the wiring harness to the speedo gear. I tried swapping out the instrument cluster and the issue still persists. I also hooked up a digital speed reader/guage to the PCM to see if the PCM speed reading matches the instrument cluster and it does. It jumps around like crazy too. I've done a lot a research and have received several suggestions that it could be a ground wire issue. I'm not the best with electrical stuff in cars and I need some help locating any/all ground wires that I should look to as the problem. Can anyone help me locate the ground wires that I should check? I did find one article showing locations for ground wires on a Jeep Cherokee WJ but I'd prefer to get something specific to a TJ unless everyone agrees the grounds will be in identical locations in a TJ. I have not tried to reference the article to my TJ yet. Unsure if its related but my after market stereo wont hold the time. It always resets on every start up and the bluetooth feature wont give me a good connection. The rest of the stereo works fine. I tried putting a new stereo with the same features and I get the same issues with it. My fuel gauge also is off by about a 1/4 tank but once again, after changing the instrument cluster that problem has not changed leading me to believe the fuel pump is going bad. But maybe its all one big related grounding issue?? Please help! Thanks! I've attached a short video of the issue. Please feel free to email if that is easier. Leenatelborg@hotmail.com
