Something interesting
I did myself a favor way back in the mid-70's when I was old enough to drive and at the advice of my Dad.
It was to never check MPG. He said it would discourage me from driving like a normal person.
Give it the skinny pedal when I need/want it and let off when I don't.
The only thing that I used as a measurement of consumption was with my old Suzuki 250 Enduro, I set the trip meter to zero and when a hundred miles came up, I filled up the gas tank.
I've never checked any other vehicle that I've owned. Not any of the Toyota P/U's, or the FJ-40 that I drove around for 34+ years.
Remember, it's the smiles per gallon when cruising with the top down or off in our case.
YMMV
Too much work, I just complain about bad MPGs knowing my speedo is really off (low)
If I drive 50-55mph and baby it at 1/8 throttle I get 17mph out of my 10.2:1 280 cube stroker. It makes lots of torque around 2000rpms.
Trouble is i usually drive 65 on two lane roads passing idiot tourists from the city driving 30mph so I normally get 15mph.
Dang that's good. Interesting how the bigger engine gets better MPGs.
I am interested to see how mine change with the new gears. Although I suppose they probably will no matter what since my speedo will be closer to accurate
The high compression and a slightly smaller cam than the golen strokers has to do with it too. Efficiency at lower rpms.
Years ago I swapped an Explorer 4.0l into a 91 ranger with a 2.9l. It also got better mpg's.
If the torque required to move a vehicle(especially a lifted one) is outside of a smaller motors efficiency range it is possible for a larger motor to get better mpg if it's fuel consumption is lower at that torque output.
Your gears will be awesome,especially in 4lo or pulling grades.
Reactions: lBasket
Yeah makes sense, and it doesn't have to run as rich to get the power to keep going? I do wonder what MPGs my MR2 will get, that motor got like 35mpgs in a 4000something pound Camry, so it might be similar to your ranger.
I am so stoked to drive it with the new gears!!! I have a feeling the break-in miles will be a fun excuse to drive the crap out of it
Reactions: ColoJeep and Rickyd
I think I could coast down The Grapevine, in neutral, drafting a semi, with a tail wind - and I would still get 10…:(
YMMV
Gas prices are what they are, I'm not driving out of my way to save a few cents.
But, if I notice my milage dropping I can start looking around to see what is causing it.. Air filter, catalytic converter etc. It's more an indicator of overall engine condition.
WOOSH
Mac is referencing a now legendary thread where somebody claimed massive mileage or HP gains after switching to a fram oil filter. I haven't collected enough data to neither confirm nor deny their claim. ;P
I've searched trying to find that post, I remember it started a few years back though !
I've owned my TJ for two years and have always kept track of milage. I have a Fairly similar routine. It has varied between 15.1 and 15.8mpg.
I replaced the spark plugs with Champion Platinum's when I bought it.
I read here that the best plug is a double Iridium plug so I put some in last month.
My first two fill-ups averaged 16.8 and 16.4mpg.
That's just too much to call it chance!
I really hesitated to revive a thread that I thought had died, but...I filled up the fourth time since changing the spark plugs and got 16.45 gpm.
In two years of driving I only broke into the 16s once, barely, and now three out of four fill ups are mid 16s .
other than the plugs the only thing that might have changed is the blend of gas I use. Same station and I'm pretty sure they don't run a winter and summer blend.
Are you filling at the same station and the same pump ? Not being at the same level will change when the pump shuts off. You also may be seeing different levels of ethanol in the gas.
Dave
Reactions: Rickyd
Dave
Good thinking. Same station but I take any available pump.
I know one mile per gallon is not much improvement, but after monitoring my milage for two years, to see that improvement immediately after changing plugs was interesting.
