2001 2.5. No AC. Loud squeal from one of the pulleys started after changing manifold gasket. While the PS pump was off I bought a new belt. After installing now have a pretty loud squeal. I've adjusted the idler pulley so there is about 1/4" deflection in the belt. Removed everything...checked both idler pulleys and they feel and sound fine. Its seems like the noise is coming from the fan pulley. Its there a replacable bearing? It happens when the engine is cold. After heating up for 10 minutes the noise stops.
