I have looked at other threads but didn’t find what I was specifically after.
I have a 1999 Sahara and want/need to treat some rust spots along the frame and other places and replace a floor pan. Here are the things I seek guidance on.
1. To treat the inside of the frame I am planning to remove as many flakes, etc from the inside and considering using Eastman internal frame coating. What is the best way to remove any flaking and is Eastman a stand alone recommended product.
2. I need to replace the passenger floor pan. I plan to cut out as much of the floor as needed treat the margins with Eastman rust converter, inside and out, pop rivet a new pan in place then paint with Eastman rust encapsulator. Is this the right method and are these the right products to do the job? Do I still need to paint or can I skip the encapsulator and just paint after the converter?
3. Other areas with light surface rust I want to sand, wire brush the surface rust and spray with rust converter or encapsulator. Have I got this right or do I just need to use converter and a paint?
Long post. All feedback appreciated. There are so many products out there and I don’t think they explain the sequence of product application very well for different scenarios.
