Rock Sliders / Rocker Guards Guide
i have a question about slider installations. now i know trying to seal against water between the slider and the body is out of the question . better to let it drain. so in order to avoid all the little grit and rocks which are bound to work their way in would it be advisable to run a bead of silicone just on the top ?
I’ve seen this done. I can’t see why it would be a bad idea. I personally thought some welting between the slider and tub would be good, but I could be wrong.
The factory sliders on Rubicons come with a gasket of sorts. It did not prevent rust through...I had rust on both the rockers and the inside on the sliders.
I hear ya! When I cut through all the baloney and got the good advice from @mrblaine, it narrowed the search down very significantly. The only two that meet all teh criteria, as far as I can tell, and that I know of, are Savvy and Genright (Mini Boat Sliders), that’s if you want the best, and something that will holdup to some serious hits. If you want them for looks or light stuff, maybe some other brand would work. I should re-write the guide! LOL
Looks like the Rokmen Mercenary sliders are W2W and also avoid a 90 degree bend. Anyone have experience with these?
https://www.rokmen.com/mercenary-rock-sliders-202.html#
Sent from my Pixel 2 using Tapatalk
They’re great, but they dont make them anymore. This is very distressing. You’re absolutely right, though, great design. They really need to update the website so people stop thinking they are still offering them.
This is a compilation of my research for rock sliders. I hope it can serve as a guide to others who are looking for the best product for themselves, as well as an avenue for others to add updated data as this forum grows and products develop. This post has undergone several edits, especially after the comments and suggestions of @mrblaine. Thanks to him for his knowledge incorporated herein and under his own post later in the thread.
Rock Sliders/Rocker Guards
Rock sliders are an important armor component for protecting your tub between the front and rear fender. They come stock on the Rubicon, but if you wheel on another model in conditions that put your tub in danger, you may want to consider aftermarket rock sliders. Even if you have a Rubicon, you may want a beefier slider for your style of wheelin’. We're not talking nerf bars here, but if you want nerf bars, you might consider reading up on rock sliders, as they may be a better choice for you if you wheel!
Many considerations go into choosing the best rock sliders for your application. Are they mainly for style? Or are they required for function? A good driver can use them to pivot over rocks. Would you like a step to help get into the Jeep? Or that lady friend, wife? How much protection do you want underneath? Do you want to protect your body mounts? Or just the edge and side of the tub? How do they mount to your Jeep? Do they mount only to the side of the tub or also underneath? Do they tie into the body mount? Or use an internal bracket that utilizes the seat mounting hardware? Are you considering aftermarket flares? Or do you already have some? It may be best purchase sliders from the same company that made your flares so everything ties in well. Or you may have the skills to fabricate a way to fit various components together. Does the mounting hardware leave a head extended or are they countersunk? Which is really better? An extended head near the lip of the tub could snap off if you hit a rock, but if tucked farther back is not a problem, and much stronger. And of course, what is your budget? These and other questions are part of determining what might be best for YOUR Jeep and YOUR use!
Below is a list of more well-known rock sliders available as of January 2018. Hopefully this bit of research will help in your search. If you find any others I’ve missed or haven’t considered, and are worthy of being posted, please let me know and I’ll add to the list. If there's data you have to fill in, also, let me know. They are divided into two classes, those with more form and less function and those with more function. Most are in the first category. So if you are looking for function, only the last few are really going to save your rig on the rocks!
Form over Function Sliders
Rugged Ridge ($299-399)
Model: 04-06 TJ
Warranty: 5 year limited
Manufacturing: 3/16” steel plate
Step: Yes (2” wide)
Mounting: Side of tub. Bolt heads are not flush. Underneath unclear
Finish: Tough Black Texture
Weight: 68lbs for the pair
Cost friendly, works with most aftermarket flares, has cut outs for use of a Hi-Lift jack, includes rubber welting to protect the paint and body.
http://www.ruggedridge.com/heavy-duty-rocker-panel-guards-11504-15.html#product_tabs_additional_tabbed
Motobilt ($275)
Model: TJ
Warranty:
Step: No
Mounting: Side of tub countersunk and underneath attached to body mounts
Finish: Bare steel
Weight: unknown
Motobilt is making some interesting products in the Jeep world. These look solid and at a good price point. If I didn’t want a step and I was on a budget, I’d buy these hands down. Made in the USA.
https://www.motobilt.com/jeep-tj-rocker-guards-with-stock-flares.html
C&C Fabrication ($225-328)
Model: TJ, LJ
Warranty:
Step: Yes, 1 ¾” x 0.120 DOM with nice plate for step.
Mounting: Side of tub. Underneath NO MOUNTING BOLTS, 2" lip underneath the edge.
Backing Plates: No
Finish: Bare metal
Weight: ~40 lbs. This is what I was told over the phone, seems incorrect though.
C&C Fabrication looks like they make solid stuff. Hard to tell a lot, but these are not mass produced, allow 7-10 days for build and 3-5 days for shipping. They have several alternate options, including a DIY version for $225.
http://shop.ccfabs.com/Rock-Sliders_c8.htm
Genright Standard Rocker Guards w/Bars ($399)
Model: TJ, YJ or CJ-7
Warranty:
Manufacturing: Laser Cut and CNC Formed from 3/16” steel.
Step: Yes, with dimple die step plate for traction entering and exiting (4 ½” wide). Side bar is 1 ½” x 0.120 thick DOM tube (angled 15* upward)
Mounting: Side of tub and underneath tub. Bolt heads are countersunk on both for a smooth sliding surface
Finish: Powder Coat Black
Weight: ~81 lbs
Genright makes a very solid rock slider. This is the cheaper model with form over function. May require some trimming.
https://genright.com/products/tj-yj-cj-standard-rocker-guards-w-bars-steel.html
Warrior Rock Sliders ($)
Model: TJ
Warranty: 180 days materials and workmanship
Manufacturing: 3/16” plate steel
Step: Yes, tapers from front to rear, or no.
Mounting: Side of tub. Underneath unclear
Finish: Black Powder Coat
Weight: Unknown
Warrior Rock Sliders provide 6-7 inches of protect under the tub.
http://www.warriorproducts.com/cata...-06-jeep-wrangler-tj/side-steps/rock-sliders/
Rock Hard 4x4 ($300-340)
Model: TJ
Warranty: Lifetime
Manufacturing: Laser Cut 3/16” steel
Step: Yes or no. 1 ¾” x 0.120 DOM
Mounting: Side of tub countersunk and underneath countersunk for a smooth sliding surface
Backing Plates: No
Finish: Black Powder Coat Semi-Gloss 20% Texture
Weight: 60 lbs
Rock hard is 100% made in the USA, not the 75% legal standard. There is no welding or cutting required and can be used with 99% of flares and all body lifts. Since black powder coat is included, this is another slider that is hard to beat at that price point…
http://www.rockhard4x4.com/product_p/rh-3001-sc.htm
Metalcloak Rocker Rails ($399)
Model: TJ
Warranty:
Manufacturing: 7GA hot rolled steel plate
Step: Yes, 1 ½” x 0.120 steel tubing
Mounting: Side of tub in two linear paths, one above the step and one below.
Finish: Bare metal or Black Powder Coat (+ $124)
Weight: 94 lbs for the pair
Metalcloak makes good stuff and is known for good customer service. These rockers have a deflector plate, high lift mount, and are designed to integrate with the MC fenders, but can be used without them.
https://www.metalcloak.com/Rocker-Rail-Pair-TJ-p/2312.htm
ARB ($466-492)
Model: Short Wheelbase TJ’s only
Warranty: Two years materials and workmanship
Manufacturing: Tough, 1.25 diamter schedule 40 tubular steel
Step: Yes (@30* upward from tub) or no
Mounting: Side of tub. Underneath ties into body mounts giving about 7 inches of protection underneath.
Weight: 63.5 lbs for the pair
ARB has a long-standing reputation in the Jeeping community for making great products. This slider is no exception.
http://store.arbusa.com/ARB-Rock-Sliders-With-Steps-For-Jeep-TJ-2-Door-Model-4450010-P3391.aspx
Warn ($329)
Model: TJ, LJ, YJ, CJ7
Warranty:
Manufacturing: 3/16” Steel
Step: No
Mounting: Side of tub not countersunk and underneath, but unclear how
Weight: unknown
Warn is a well-known and reputable company, mostly for their M8000 winch.
https://www.warn.com/truck/mounting-systems/rock_sliders.jsp
Rokmen Mercenary ($399)
Model: TJ, LJ, YJ
Warranty:
Manufacturing: Precision Laser Cut and CNC form bent from 3/16” steel plate
Step: Yes, slider is 1 ¾” DOM Tubing
Mounting: Side of tub countersunk stainless steel. Bottom of tub countersunk alloy for smooth sliding surface
Backing Plates: Yes, 10 Zinc Plated.
Finish: Bare metal
Weight: Unknown
Will work with all body lifts and gives full underbody protection, fully TIG welded and all grade 8 hardware. Welds are hard to beat. This is a very good slider at a very good price. Very hard to beat! No longer in production as of 1/2018. Possibly will re-enter production if demand increases.
Poison Spyder Rocker Knockers with Sliders ($375-415)
Model: TJ, LJ, YJ or CJ-7
Warranty:
Manufacturing: Laser Cut and CNC Formed from 3/16” plate steel.
Step: Yes, DOM tube
Mounting: Side of tub countersunk and underneath tub at the body mounts and ribs, etc…for smooth sliding surface
Finish: Bare Steel
Weight: Unknown
Poison Spyder makes good stuff, and this rock slider is no exception, and at a price point that is hard to beat. Works with a body lift without a resulting gap or misalignment.
https://shop.poisonspyder.com/TJ-Rocker-Knockers-with-Sliders-p/14-08-060.htm
TNT Customs Standard Rocker ($270-350)
Model: TJ
Warranty:
Manufacturing: CNC cut and formed 3/16” steel plate
Step: Yes or no. Step is very nice, 3.5" wide
Mounting: Side of tub and underneath, neither countersunk. Explanation from TNT is that it weakens the steel at that point. They have never had a bolt head messed up to the point it could not be removed. Optional internal brace ($89).
Finish: Bare steel
Weight: 72 lbs
TNT Customs rock sliders look pretty beefy. Gives full underbody coverage and is body lift compatible. There is a double angle as the slider comes around the edge of the tub. It is not as demarcated as the Savvy and Genright's below, but is surely superior to all the previous rock sliders on this list. It is not wheel well to wheel well, but fits with their flares. A very strong option for someone looking for something that is very nearly in the upper echelon of functionally superior sliders, but not willing to spend $600.
https://www.tntcustoms.com/jeep_parts/tj_rock_sliders_97_06_wrangler_tj_tnt_customs
JCR Rock Sliders Crusader ($459+)
Model: TJ, LJ, YJ
Warranty:
Manufacturing: CNC cut and formed from 3/16” steel
Step: Yes, (3 ½” wide)
Mounting: Side of tub and bracket inside tying in to the seat mount locations.
Finish: Bare metal or Black Powder Coat (+ $150)
Weight: 92 lbs for the pair
JCR makes solid stuff for our Jeeps. This mini boat slider has a unique look and claims to provide higher ground clearance than traditional angle steel tube sliders. Has built in Hi-Lift jacking points front and rear. It is wheel well to wheel well and has the interior tub support that ties into the front seat, so this makes it an excellent functional slider. Made in the USA.
https://www.jcroffroad.com/product/SWBSL-CR.html
Function Over Form Sliders
Genright Mini Boat Side Rocker Guards w/Bars ($599)
Warranty:
Manufacturing: Laser Cut and CNC Formed from 3/16” cold rolled steel. Side bar is 1 ¾” x 0.120 thick DOM tube (angled 15* upward)
Mounting: Side of tub and underneath tub. Bolt heads are countersunk for smooth surface
Finish: Bare metal
Weight: Unknown
Genright makes a very awesome functioning rock slider. The design incorporates a 45* angle around the edge of the tub. This is far superior to the 90* angle on most rock sliders. It will allow you to slide, whereas a 90* angle will often dig into the ground or rock and cause you to stop. I consider this a design feature that makes these the highest quality functioning rock slider. They also have as an option an interior support bracket, which will mean that your tub will not bend outward when someone uses the step. Again, this is a high quality addition, not common to most rock sliders. Provides wheel well to wheel well coverage. May require some trimming.
https://genright.com/products/tj-yj-cj-mini-boat-side-rocker-guards-w-bars-steel.html
Savvy Rocker Steel Slider ($559)
Model: TJ
Warranty:
Manufacturing: Aluminum base.
Step: Yes, replaceable
Mounting: Nutserts, reinforced backing plates, all stainless steel
Finish: Raw
Weight: ~80 lbs
Savvy, the name says it all. The design incorporates a 45* angle around the edge of the tub. This is far superior to the 90* angle on most rock sliders. It incorporates a two-piece design, the slider and the step, so that if one part is damaged, the whole does not need to be replaced, only one piece. They also have an interior support bracket, making them much stonger than most sliders. This is a great option for someone who will be on the rocks. It provides wheel well to wheel well coverage.
http://shop.savvyoffroad.com/Savvy-Jeep-Wrangler-TJ-Rockers-w-Step-Sliders-1997-2006-RKR-Kit.htm
Nemesis Billy Rocker ($649)
Model: TJ
Warranty:
Step: Yes, flat with lip
Mounting: Countersunk on sides, underneath it completely covers the body mounts and goes all the way to the frame providing total protection.
Finish: Bare, Semi-Gloss or Textured Powder Coat (+$200)
Weight: 55 lbs for the pair
Nemesis makes an interesting rock slider. The entire side of the Jeep lower tub is protected and even the body mounts are completely covered. They are aluminum to boot, so just 27.5 lbs per side will be added to your Jeep. It doesn’t come without a price tag though! Maybe you get what you pay for. Hard to say but definitely worth a hard look. They also provide a 45* sliding surface, which is superior to most other rockers. With their under body mount wrapping design, you will lose some clearance. Coverage is wheel well to wheel well, which is superior to most rockers.
https://www.nem-ind.com/products/jeep-wrangler-tj-accessories/97-06-tj-billy-rocker.html?___SID=U
Apologies for leaving others off like Smittybilt, Ace Engineering, et. Al., as well as some of the alternate versions specific to your TJ or LJ, flare set up, etc...However, I hope this helps folks find what’s out there and make an informed decision. As for myself, I still can’t decide, but the top contenders are Genright Mini Boat Sliders, Savvy, JCR, TNT and Poison Spyder. Hope to see you on the trails!
Thanks JMT for this excellent compilation of TJ Rock Sliders. Great write up.
Fonz
Reactions: JMT
I think you need to read some of this thread with an open mind.
Where I live we have a lot of sandstone, so it's mainly individual sections of track that you need some sill protection. Currently, I'm not driving the harder line on these sections. So need something there to give me the confidence to tackle these lines without walking away with a damaged sill.
Whilst Blaine's interpretation of the requirements suits his use, I personally feel the Savvy sliders are too heavy, too exxy and whilst I can see the potential benefit of the removable slider section, have never bent an ARB slider or the tube step on them despite coming down quite hard on them numerous times on some of the more difficult tracks locally in a previously owned TJ. I'm also not a fan of the aesthetics of the Savvy version (personal opinion).
So for me, I'm again fitting ARB versions, disclosing that locally with a 4x4 club discount they are half the cost of importing most anything else from the USA.
We have a step option at Motobilt. I have them on my TJ.
https://www.motobilt.com/body-armor-bumper/rocker-guards/jeep-tj-rocker-guards.html
I did on my 97 TJ. I asked for the LJ and he said he'd have to cut on weld two sets together because of the length. Great product, can take a beating and made in PA. I used quadratec this time for the free shipping and called zac to add the body gasket to the order. He said he gets paid regardless so I figure let quadratec eat the shipping.
Finally got some high resolution pictures of the Warn rock sliders that are now a little better, a little custom.
As soon as I saw the Warn sliders I fell in love. They are the most aesthetically pleasing in my opinion. I love the lower rounded bevel that wraps around the bottom edge of the tub. The Warn sliders do lack a step which I feel is very important for a lifted TJ/LJ. So I added one to each side and threw some skateboard grip tape on em. They are now the perfect combination IMO. It also protects the actual slider from dents, dings, and scratches.
Check em out.
As soon as I saw the Warn sliders I fell in love. They are the most aesthetically pleasing in my opinion. I love the lower rounded bevel that wrape around the bottom edge of the tube. The Warn sliders do lack a step which I feel is very important for a lifted TJ/LJ. So I added one to each side and threw some grip tape on em. They are now the perfect combination IMO. It also protects the actual slider from dents, dings, and scratches.
Check em out.
View attachment 55799 View attachment 55800 View attachment 55801 View attachment 55802 View attachment 55803 View attachment 55804 View attachment 55805 View attachment 55806 View attachment 55807
Thanks for posting a pic, I've always wanted to see a close up of how the Warn lower bend was.
When you added the step, was paint matching easy? Looks pretty consistent all the way across, nice job.
My TJ is right at the height where I don't necessarily need a step (I'm also very tall so that might have something to do with it) so I like the look of these and the savvy versons.
Reactions: Fouledplugs
Haha! Yes. Finally. That gives a great view of the bend. I would not hesitate to go all in on a pair of Warn Rock Sliders. Thanks much @Fouledplugs.
Yea I needed a step being that this one is on 38’s. And then of course needed griptape because its rare to find dry trails in the South.
Did it right, no shortcuts, so had it stripped and powder coated.
After studying this, it looks like the TNT slider is the only one that protects the tub mounts. Would this make them the hands down best? I know they're expensive. Since I don't know what trails I want to run, it's hard not to go big.
