Recommendations for a "no more death wobble kit"
BigTom
Jersey
My 17 yr old son just bought his first Jeep and wrenches on it all the time. He is now looking for a replacement parts kit that supposedly will help reduce the DWs. He has found this one https://core4x4.com/shop/cmp-j-tjlj...ing-kit-1622#attribute_values=579,,686,,,,947 online and I'm wondering does anyone has some first hand knowledge or can recommend a good similar kit or is this a good one?
Thanks for any onfo,
Happy Holidays to all.
Start with the tire balancing kit.
Balanced tires and good connections fix the majority of DW cases.
Folks often try to eclipse it by replacing everything in the linkage - you can do that and then find out it was a bad tire or failing control arm bushing.
Evaluate with the dry steering test first is best.
There are several components that can be worn and allow imbalanced tires to trigger DW. Balance tires first.
Unless the jeep is bone-stock, I usually immediately think of a drop pitman arm installed.
We need pics.
Reactions: speeding_infraction
