Rear Hazards not flashing
DZ302
Washington, United States
Rear indicators and brake lights work just fine, but when I put the hazards on only the front flash. Has anyone else experienced this?
2004 Rubicon, 4.0L, 42RLE
Check the multifunction fuse in the distribution panel under the hood next to the battery. If that fuse is blown, your lights will work, but your hazards and turn signals will not.
It was suggested on another on-line gathering place of like minded individuals that it was most likely my multifunction switch. Switch has been replaced and I can report that it solved the problem. Roughly a $40.00 part and about 15 minutes to replace. You need a phillips and both a torx 10 and 20.
YES! Mine does all kinds of crazy shit. First time i push the hazard button, only the left side flashes, 2nd time only the fronts. If I jiggle it a little bit, it works fine. I know it needs a new multi function switch, just haven't gotten around to buying it yet.
BTW, where is every ones favorite "online" place to buy Mopar parts?
