Question about possibly needing a axle rebuild
Matt14
Winder, GA
So on my front Dana 44 axle, I have noticed that the pinion can be pulled out very slightly. I've been told I may need an axle rebuild but was not told what part of the axle. I did a little research on crush sleeves and thought maybe the previous owner may have overtightened the pinion nut but that is my only idea. Also how big of a deal is that? I need to reseal the axle soon so I will have it taken apart is there anything I should look for or inspect. Thanks in advance for the advice.
The pinion should have no movement forward and back. If you do either the pinion nut has come loose and or the pinion bearings are toast.
is there a way to check the bearings vs the pinion nut being loose?
You could try to tighten the nut. But really, if it has been run loose there is a high probability the bearings are toast; maybe the pinion has contacted the carrier and possibly chipped the pinion gear in the process.
Reactions: Alex01
Anyone have any advice on next steps I have a feeling this would be out of my level of mechanical ability. Is this a trip to my normal mechanic or should I take this to some sort of specialist for gears (if this is a thing)? I live in buford GA if anyone has any recommendations for around here.
Doing the test Rob described could easily be done at your house. You'll just remove the 4 small bolts that hold the driveshaft to the yoke then put a torque wrench on the big nut that holds the pinion on. Now if you find it is to spec and there is still slop I would definitely find a gear specialist in your area.
I typed regear and Buford, Ga into google and it seems the JK crowd like AllSouth Autosports in Buford.
Thank you I plan on doing the torque wrench test tomorrow after work and if that doesn’t work I will be looking for a place like that. I have worked with Allsouth before thanks.
Reactions: Alex01
Let us know what you discover.
quick update so after pricing out getting the issue fixed. It was going to cost about $600+ to fix just the issue because I would have been essentially regearing just the front. After calling around Jasper Jeep hut priced me 1400 to regear and reseal both axles. I had the rubicon 4.10s and since I am running 35s decided to go with 4.56 So I decided to go ahead and do that.
Have you already had the gears replaced? Most would go with 5.36 with a 42lre and 35's
4.56 will be a huge mistake, unless you plan to drop back to the stock tire size. 5.38's all the way, or not at all.
