PRNDL's Green Jeep
Opened the rear diff last night. My oldest volunteered to help. Its nice to have extra hands to hand you tools. I quickly learned your helper needs to know the names of tools to be... helpful. I did get really good a describing where and what to look for. :LOL:
I started working on the locker air fitting replacement. Getting the old one out is going to be more challenging than expected. Gears, oil and everything else look to be in great shape.
i am a fan of lubelocker diff gaskets
Reactions: hear and PRNDL
Huge thanks to @Mike_H for his write-up on replacing the factory locker air fitting. These are running $100-125 online these days. Following his instructions, I put together a homemade replacement.
After fighting with and removing the rusted original, the replacement slid right in. The copper tube is line to line and the pressure holds. This is the test fit before adding JB Weld.
I have a set of functioning lockers!
The front line has an air leak somewhere. It locks, but the pump runs every 3 seconds or so. I'll diagnose that some other day.
Lots of updates over the past few weeks. Christmas brought GraBars and a Spiderweb shade and the time off from work let me tackle the lift. Pretty much nothing went smoothly between the rusted bolts and trips to the hardware store for sockets and drill bits. I even managed to smack myself in the face with a crowbar fighting with the front track bar. The toughest parts were getting the rear track bar back in and the seized tie rod.
Complete Savvy Control Arms
JKS 3" springs
Rancho 5000x 55239/55241
RockJock front track bar
BMB Johnny Joint Washers
OME Track Bar Bracket
New jounce cups
Zone sway extensions
Still to install:
New rear jounce bumpers
New front spring isolators
Rock Krawler bump extensions
JKS Angled track bar bracket
On order:
Tom Woods rear driveshaft
Rears:
Fronts:
Still a list a mile long of things to do.
  • Tires. I need them. I'll be ordering the Cooper Evolution M/Ts in 285/75r16 from Discount Tire in the next week.
  • Cycle suspension, set bumps and measure shock travel. At first blush I think these shocks might be too short. As it sits, there's probably 70/30 up/down travel. I need to get actual measurements. @Farmergreg - I think you have this same spring/shock combo, though yours is an LJ. Did you have any concerns with shock travel on yours?
  • Set control arm lengths for caster and wheel well centering. I really only adjusted the rear uppers to get the rear pinion as happy as possible with the stock driveshaft. I've had it out around town a few times and I might be getting a little low "growl" on acceleration. New tom woods shaft is ordered.
  • Paint shock bodies assuming I keep them.
  • Rear adjustable track bar, probably the JKS OGS151.
My Savvy body lift shipped and should be here today! I can finally get around to painting and install the UCF extra clearance skid out the shed. Which reminds me, I need to order a MML and Savvy cable shifter.
Getting there...
Looking good, but damm making me nervous for this weekend. It was either $600 for the shop todo my lift install or 10k Delta miles to fly in my friend who’s “installed his lift so many times I should just do it”. He lands Thursday… any last minute words of advice or feedback on my tools? This will be my most ambitious project so far.
I’ve got full set of hand tools, sae/metric ratchet wrenches, pry bar and breaker bar, 1/4/3/8 and 1/2 socket set, floor jack, ratchet straps, 4lbs of BBQ brisket for slow cooker and still to pickup are better than PB blaster & beer.
Reactions: PRNDL
Jack stands?
Reactions: PRNDL
Mechanic's creeper and a good light (headlamp or work light) for underneath the Jeep
Reactions: Wildman
JKS 3" springs
New jounce cups
Still to install:
On order:
Rears:
View attachment 299339View attachment 299340
Fronts:
View attachment 299341View attachment 299342
Lookin Good! I love electric lime green...
Getting there...
I don't recall the shock absorber part numbers, but I believe they were for a 2" lift. Pretty sure I have 2" of bump stop on the bottom pad. But I'd have to measure the bias to be sure. It's been about three years now so memory is fading a little. Everything is holding up well. The JKS springs still have air space between those tighter top coils. I just had it on the hoist in prep for dragging it out to arizona.
You've got a great looking TJ and build in an unusual color!
Here was a pic from this summer when my son and I were comparing flex on our rigs (his K-30 in the background):
@red02tj this. My headlamp was my most appreciated tool.
First off, you've got this. It's totally doable. I did 95% of it completely solo. Having a blocked off day and another set of hands would have made it a breeze.
I had a pair of 6 ton jack stands for the frame, but I also made use of a smaller set for the axles at times. You'll need a torque wrench as well, the frame side of the front track bar needed 125 ft lb. I also made a lot of use of a large crescent wrench. I don't have a wide range of larger box end wrenches. it was kind of my catch all when i needed something to hold a bigger bolt.
I needed bigger sockets for my front trackbar and control arms. I have a decent mechanics tool set, but needed some on the bigger side. In the end, I bought 15/16, 13/16, 7/8 and 21mm sockets, 7/16 12" and 5/8 drill bits and a cheap tap kit from harbor freight.
Awesome. I'll cycle everything and see where i end up. Thanks!
Reactions: Wildman
Oh, and a propane torch. If you have any rusty bolts, it makes them easy.
Reactions: Wildman
easier...Propane won't touch a truly rusted bolt. Oxy/Acetylene (or a welder) is needed then . I had some body mount bolts that were seized solid...took a couple tries welding a nut to them to get em to move. Bumper bolts too. A good impact combined with heat is probably the best tool you can have for rusty bolts. Get it good and hot, then work it back and forth with the impact. Rinse and repeat.
Fair point. My experience with "rust" down south and your experience with real rust are not the same. A quick hit with some heat did make several old brown bolts and my tie rod break free after struggling with it soaked in Kroil.
Reactions: Mike_H
Thanks for all the tips. I’ve got a creeper and some good headlight/world lights and I’ll pickup a propane torch this weekend. I’m hoping my rust is like PRNDLS based on being in the south and what the undercarriage looked like when I got it up on the lift before purchase.
Reactions: Alex01 and Huckster
