Pre-runner lights?
Curious about what you are going to use.. got a link?
Grille inserts:
https://www.extremeterrain.com/drake-grille-inserts-tj-jp190018black.html
Trailer marker lights:
Partsam 2PCS 3 LED Truck Trailer Front Rear LED Side Marker Lights indicator Lamp Sealed & Waterproof Surface Mounted Installation Amber 3.9" https://www.amazon.com/dp/B00YLWX0SC/?tag=wranglerorg-20
wiring harness:
https://www.extremeterrain.com/raxiom-led-switch-kit-j100996.html
OE gang rocker switch:
Fits The Jeep® 1997-2006 TJ/LJ Rocker Switch- Zombie Lights Logo https://www.amazon.com/dp/B00FGXF2Y0/?tag=wranglerorg-20
I thought about wiring them into the passenger marker and just having them as running lights, but I also thought I might like to have independent control of them and for the low cost and effort, I’d rather not monkey with my factory wiring.
Here's how the first draft turned out:
I'm a little disappointed. I was hoping to mount the markers higher in the slots but the slight bend in the grille didn't cooperate with the baseplate of the marker. I do like the grille inserts though and this setup didn't require me to do any modification to them. I'll likely keep shopping for alternative markers now that the wiring is complete and try to find something that is smaller and mounts near the top of the grille.
Really like the wiring harness as well. Went with a Nilight 4-lead harness and ran it into the 4-gang OE switch in the dash.
I used these on the kids power wheel gator, really bright and it’s only a 5/8ths hole. You definitely want to recess them if they are going in one of the grill things.
