Kevin E TJ Enthusiast Original poster Lifetime Supporting Member Joined Nov 1, 2015 Messages 866 Location Wharton, TX Jul 10, 2021 #1 I am upgrading my coil springs and shocks. Is there an easy way if removing overspray form aluminum??
MichaelGH Hemi ‘97 Supporting Member Lifetime Supporting Member Joined Jan 19, 2021 Messages 1,002 Location OHIIIIIIO Jul 10, 2021 #2 I use aircraft stripper if there is a lot of paint to remove or acetone if it’s not too bad. Just need to make sure neither product gets on any painted surfaces that you don’t want blemished…
JMT The Silver Fox 🦊 Supporting Member Ride of the Month Winner Joined Feb 27, 2017 Messages 26,420 Location 🌎 Jul 10, 2021 #3 Kevin E said: I am upgrading my coil springs and shocks. Is there an easy way if removing overspray form aluminum?? Click to expand... If you can access it, scuff it. I don’t know what acetone will do to Al.
MichaelGH Hemi ‘97 Supporting Member Lifetime Supporting Member Joined Jan 19, 2021 Messages 1,002 Location OHIIIIIIO Jul 10, 2021 #4 JMT said: If you can access it, scuff it. I don’t know what acetone will do to Al. Click to expand... Acetone is safe to use on aluminum and even anodized aluminum. We use acetone to remove the lettering/numbers from the manufactures as well… Reactions: Kevin E and JMT
