"Pacing myself" build
Engine light came on Sunday. Checked it yesterday, Camshaft position sensor code. I just replaced that synchronizer 6 months ago with a Standard Ignition unit. Checked the plug and the wiring. All looked good. Apparently not, got in to go home and no starty. Luckily I hung on to my old unit, so I took the CPS off the old synchro and replaced it. Just another example of cheap China crap and Mopar not liking it.
So, I get nothing from the dash or floor. Only defrost. I poked under the dash and checked the actuators. Where should I start looking?
IIRC that’s a vacuum leak. Check the vacuum line under the hood.
Reactions: zebra12
Mine was above the throttle pedal, one of the connections was loose.
Reactions: bobthetj03
Ended up being the air line that goes into the firewall was cracked. 1/8 vacuum tubing to the rescue. While I was at it, I finally installed this beast!
Is there a preferred configuration for the clamps?
I prefer that configuration of the clamps on the passenger side because it avoids having contact with the steering damper under articulation. I'm not sure the driver's side matters, so I prefer to get it up as much out of the way as possible, flipped over.
Reactions: Irun and bobthetj03
That was my thought as well.
Reactions: Irun and JMT
Wish I hadn't seen this. In May I replaced the one on my '04 LJ with a SMP sensor. :(
20220529_141608-jpg.334052
  • Sad
Reactions: JMT
Not a lot of choices for a replacement. I'm keeping the original Mopar one on until it fails and have that PC380 in the glove box for when it does.
Reactions: Irun
