First and foremost, start with the obvious. Make sure your battery terminals are clean and tight. Corrosion or loose connections can lead to starting problems.
Since you're getting dash lights and everything else is functioning normally, it could be the ignition switch itself that is failing. Try wiggling the key or turning it slightly to see if it affects the starting process.
Finally, check the starter relay and solenoid for any signs of wear or failure. Sometimes these can cause intermittent issues like the one you're describing.
Starter has been replaced because it was original to the jeep and had given me a few different issues intermittently before so I just went ahead and replaced it hoping it would be my issue. It was not. I bypassed the clutch safety switch and it still did not start. Battery is clean newer and all connection are tight. Im going to switch the starter relay out with a new one. There is 12v power to the relay terminals. The relay itself read nothing on my ohm meter.
