The reason I haven't commented on your welds is everyone else has given the same advice I would have.
You have a bit too much tip movement side to side. Beginners should learn to weld without patterns, C, cursive e's, S's, or any other letter of the alphabet until they get very consistent with heat and speed.
For your inside corners, hold the gun at a 45 degree angle to the weld surface and if you are pushing, lay it back at the same angle. For the one in the pic, move towards the left a tiny bit more so the weld starts down on the other weld and work on the tie in. As you get to the end of the weld on the right, pause the gun for a fraction and let the crater at the end fill.
You are running a tiny bit hot and laying down a lot of material. You could keep the same settings and move a bit faster, (hard to do consistently) or, turn the voltage down just a bit.
As you get more practice and learn what welds look like by what you did, you'll pick up small movements to make the puddle do what you need to improve them in certain situations. If you start with movements trying to make the weld mimic something else, then that will always be a crutch you depend on rather than good welding technique.
For now, concentrate on consistent speed, steady platform and brace the gun so you can move the full length of the weld without having to reposition your hands, concentrate on consistent tip angle, and just move through the weld watching the deposition rate to build the width of the weld with a constant distance away from the surface to control electrode stick-out.
