New starter squealing
Christian.mers
Point A to Point B
Huntington, West Virginia
I just put a new starter in and when I start the jeep it makes a loud squealing noise and the jeep starts up fine and runs fine and doesn’t make any grinding noises or anything. No issues except a loud squealing noise upon startup. Took it in and out 3 times and made sure everything was spotless all 3 times
New starter noises or install error??
I cannot pull it down today, but does the 2.5l starting need shims or anything?? I was looking at the old and and the new part and neither of them had a visible shim
I did no testing, just compared parts and slapped it in. I’ll check it out tomorrow. Any special testing ideas besides hooking it up to a battery and seeing it operate?
No. Just pull it and test it out of the Jeep. Or take it back to the parts store and have them test it. The starter has a bronze bushing on the shaft that if dry it’ll squeal like your talking about. You’ve still got to replace the bad starter cause oiling that dry bushing will only be a temporary fix.
When I replaced the starter on my 2.5L, the new starter squealed, but I found a little dirt in the joint when I took it back out.. Cleaning that up did stop the squeal. I see you have already checked that.. Sounds like you've received good advice above. I know when I rebuilt the motor I had to fight a batch of bad head bolts and a bad (new) clutch fork clip, and I'm having a hard time trusting new parts these days
Reactions: ColoJeep
Pulled it out in the Autozone parking lot, they tested it and it passed. I’ve tried cleaning it up real good but I pulled it back out and always find oils and fluids. Anything look strange?
The FSM for my '99 does say that "Shims are available and can be used to adjust the 2.5L starter motor mounting position to correct
for improper starter pinion gear to starter ring gear engagement" (page 8B-3). In another spot is says they are 0.015" thick and can be stacked if additional thickness is required. Later (pages 8B-7 and 8B-8) it says a shim can be added if a high frequency whine exists just after the engine starts, but if the same whine exists just before the engine starts to remove shim. Is your new starter remanufactured, and possibly had a shim originally? Do you see any differences in the engagement patterns on the starter teeth (old vs new starter) that might say if the new one is engaging 'less' of each tooth? I don't know if any of this will help, but maybe it will.
Reactions: Christian.mers
My FSM states the same things. The high frequency is upon starting and immediately stops directly after the starter is disengaged and the engine is operating.
The replacement starter was a brand new Mitsubishi unit from Autozone. No shims were used on my Previous or Current starter. It’s pretty difficult to see starter to flex plate engagement because I can’t really fit my head of phone in there. Potentially an inspection mirror??
I haven’t used the new one much, maybe 4-5 starts so I haven’t got a good view of the contact pattern but from what I can see with those few starts is it looks like the engagement on the new unit is superficial compared to the OEM unit
EDIT: The little black part at the very end of the Starter shaft also appears to be half the width so I’m not sure what that’s all about
I hate the stupid E12, I just picked up a whole set from harbor freight for $13. Just wanted to make sure there weren’t some sort of fine details I was missing. Last night I tested the starter again and there were no issues. I attempted to loosen the starter simulating shins and that seemed to help quiet the noise.
My only thoughts now are dirty Flexplate that may have some oils if dirt or something on the teeth or this new starter just fits differently and needs some shims. Any idea where to get the Shims?
