So just to add to the "my jeep runs much better after changing my spark plugs" controversy:
After and during a trip up to the top of Maunea Kea (13,800') from the beach, two weird things happened. The first was intermittent rough rumbly running engine, the second was sticking brakes.
The brakes cleared up by the time I burned them down a bit and work perfectly once again.
The rough running seemed to happen pretty often after that trip. Sometimes it would hardly run at startup. No new codes (always have P0442).
So, after looking around, I decided to pull a plug.
None of them looked too bad, but there was some weird deposits. They looked pretty new. I've only had the vehicle for about 5 months, and it had been running well enough that I hadn't thought about the plugs.
Denso qj16hr-u, a copper core grooved plug.
I changed them out with the ones Coach recommended, the Autolite APP985 gapped at .035, and boy, what a difference. Fires up more smoothly and really revs up smoother. Better pickup for sure.
Now, I'm not really a believer in plugs making a huge difference, but, in this case...big difference. No drugs or DIY delusional enthusiasm required to note the change.
Not sure what to say, except those skimming this thread who just bought a new old jeep (mine is 2001 Sport 4.0, 136K), change your friggin plugs and put in the ones Coach is recommending. I mean, wtf, must be the coil system makes it finicky like Coach said? I've owned many Vanagons, which were very persnickety about using only the specific Bosch plug and NEVER Autolite, which will put the old vanagon right into safety mode, but this seems to be a pretty extreme predisposition.
Now, what about my brakes. I used 4wd Low so as to not overheat the brakes on the steep descent. Did not lean on the brakes much at all. But it seemed like the rotors warped. Except they then straightened out by the time I was back on the highway for a half hour. Maybe the ABS was firing as I was skittering down the gravel? I thought its off in 4L?
Hmmmmm.
Hmmmmm.
