Hello All...
I have owned my 2001 TJ auto with 4.0 since new and despite some of the issues with occasional leaks (RMS, valve covers, radiator), the engine has always run like a top for over 20 years. Truthfully, the only time I have ever experienced the check engine light was for an EVAP code. Within the past 2 months, the engine finally would not start which after some research here turned out to be a bad crankshaft position sensor.
The problem is there are no factory MOPAR CPS sensors available. I placed a few orders at places like moparpartsgiant which were quickly canceled and an ebay search also turned up nothing. I ended up installing an NTK unit that is labeled as Made in USA and everything seemed to be working great until last week. As a weekend vehicle, I do not drive it very much and finally got it above 3500 rpm or so on the highway and the check engine light comes on. There was no stuttering or noticeable loss of power while I was doing close to 70 at the time. Pulling the codes returned P0304 and P0306 for cylinder misfires.
This seems too much of a coincidence to be not related to the new CPS but hoping to hear some thoughts.
At this age, could the camshaft position sensor also be going bad? Factory MOPAR replacements for these are also NOT available but I have an NTK unit on the way that I can try.
Could it be old plugs and injectors? The fact that I received 2 codes suggests that it is something else but I really do not know. Are worn timing chains a thing with the 4.0?
Or should I try switching to another sensor brand like Tammken and cross my fingers? These appear to be made in China from all indications and the NTK unit that I installed does seem to be pretty good quality with the only difference being the spacer pad installed at the end compared to the original unit it replaced.
Thanks.
Thanks.
