My first Jeep :)
TheYonderGod
Northern CA
I've been dreaming of getting a 4x4 for a few years, finally made it happen about 2 weeks ago when I found this 2000 TJ, 4.0L, 5 speed with 220k miles listed for $6500 (California prices, btw). PO before the one I bought it from told them that most of the miles were from being towed behind an RV, I found out that may or may not be true depending on how they towed it. They mentioned a few problems, the axle leak and the dead a/c. Smog was already passed recently which is a big deal in CA, most of the Jeeps and Samurai I had been looking at hadn't done this yet or even refused when I asked them to smog it after I look at it but before I pay for it. Seems like a good deal without being too good to be true, so I went to look at it. Just a little surface rust on the frame, nothing crunchy or flakey. Engine sounds great and transmission seems smooth as far as I can tell being to to manual transmissions. Steering is as good as I could expect from a Jeep, no death wobble at least. I found some small problems that I've been fixing over the last few weeks, and 2 slightly bigger problems; the engine is leaking oil a little (probably rear main or valve cover) and the blower motor didn't seem to work at all. I used those 2 issues as an excuse to offer $6000 and they accepted!
So here it is on the drive back and finally parked at home for the first time
Of course as soon as we finish the 200 mile drive home the check engine light came on, P0432. I'm still not sure if PO hid that or if it just popped up since they barely even drove it. Speaking of that, I got their receipts and see they spent over $2k in repairs and maintenance in the 3 years they had it and only drove 2000 miles, all in town/zero off-roading too🤣
I'm gonna try replacing O2 sensors but I'm expecting to have to replace a cat. I'm not too worried about it for now since smog is already passed and in my county you only have to do it once to transfer ownership, then never again.
Another slightly bigger issue I didn't discover until it was home for a few days is the steering box has a small leak. Again not super worried about it, I might upgrade it later anyways.
But I also found a bonus that I didn't know about, the rear axle was factory upgraded to a dana 44! (at least according to the VIN it is, I haven't verified yet)
So first I set out to fix the easy stuff...
Actually before I fixed anything, while I was waiting for parts I was learning how to drive stick and went out on my first real off-road adventure! To a lake about 40 minutes from my house (and half of that is slow, off-road) that I've never been able to get to before. That tree in my first picture is 500 years old and fell 2 winters ago. That also marks as far as I've been able to go down that road in my daily driver 🤣
20241015_174811.jpg20241015_175628.jpg20241015_180754.jpg20241015_180822.jpg20241015_180852.jpg20241015_180941.jpg20241015_182403.jpg20241015_182429.jpg20241015_182653.jpg20241015_184058.jpg20241015_184220.jpg
For the next 2 days the small fixes began:
Took me a minute to figure out one of the previous owners installed these pieces of sheet metal over the door light switch instead of just removing the fuse when they took off the doors. I usually like creative fixes but in this case I'm just left wondering why...
Installed this dual USB port in place of the cigarette lighter that I would never use (Also a question, what is this plug that goes to a blank switch panel? Is my Jeep pre-wired for something that I can easily add?)
Sure enough as I read about on the forums the problem with the blower motor is a melted switch. I replaced the switch but then I realized I need to order a new connector for it too since it's also melted. I think I'm just gonna go ahead and replace the blower motor while I'm at it because I read that an old worn out motor can cause a higher amperage draw and cause this problem.
My Jeep came with just a loose hood prop, so I wanted to fix that. I am soo clumsy I am guaranteed to drop the hood on my head if it's not secure 🤣
I found this strut kit before I found a place to buy the prop hinge so I thought what the hell, might as well upgrade it!
Replaced this broken side marker light for a whopping $2.58! And replacing the windshield washer pump was even easier and cheaper than I expected as well.
Welcome aboard, and have fun with it. I try to explore the Mendocino National Forest as much as I can.
Haven't been doing a lot in the cold weather. Today I designed and 3d printed a bracket for my new lights. I need to make a few more tweaks and then ill post the file in case anyone else wants to print them. I don't know how well the plastic is going to hold up over time, PLA probably wont at all once it gets hot, but they seem solid so far.
I'm still not sure if I'm going to put both lights on it, or just 1 and mount the other on my bumper. 1 is more of a flood light while the other one is a better spotlight.
Last week I installed my new winch
Just in time for today! My sister and in-law got stuck in their Subaru, so I got to do my first recovery with it 🤣
(they were stuck where those tire tracks are on the bottom of the first image, I pulled them backwards with a snatch block to the tree behind them. They did make it through the 2nd time at a better angle, that little Subaru isn't bad for what it is)
And then we went offroading for the rest of the day
