Looking for pre-cat replacement options
2005 wrangler X ?
There And Back Again
Maine
2005 wrangler X with six inline squirrels
im figuring the next thing on my jeep that will need fixing is the pre-cats and cat theres alot of coding going on
on Bank 2 changed out #1 on bank 2 --NO code now
a week later #2 rears its ugly head
changed out #2 on bank 2 and it keeps coding out at almost exactly at 130miles 3 times now
ive never had to go through a emissions test here in Maine
could any here point me to the least expensive but good replacement parts? from header pipes to tailpipe
Please excuse my terminology I ride the short buss with a smile :)
thanks
John
There was a crazy deal over the Summer you missed. Holly was clearing out their FlowMasters for under $300. All those links now appear dead
https://www.magnaflow.com/collections/2005-jeep-wrangler-catalytic-converters
$750 for PreCats and Pipe $1700 for the whole system w/3rd Cat.
https://afepower.com/afe-power-47-48003-direct-fit-catalytic-converter-replacements-front?
I went with AFE as I could source it faster at the time.
Be aware it is common to get an O2 Sensor warning (P0298 or similar) as the flanges are hard to seal. Bolts and Hardware are the culprit, the Mopar only nuts likely need replaced Part No: 6506546AA and eBay seemed to have them for $6ea
If the Cats were bad you would be getting a misfire code P0300 and possibly Limp Mode, Check Gauges lights flashing
Replacing the Pre-Cat and pipe can be done in the driveway on your own, but its is a pain. Plan to cuss and get a few scrapes. 15mm flex-head ratchet wrench will help and some wobble extensions. Also depending on the weld job you may need some creativity getting the Cats and Flanges all lined up and torqued properly. I looped a ratchet strap over and around the engine and under the Cat Pipe to help hold it in place while I was laying under it getting everything aligned.
