Jeep tj starting problem
Trucks98
Belledune
Sometimes after turning the jeep off it will click like it has no power boost it its fine then other times turn the key no power dash acts up speedometer and rpm needles spazz out turn key off and back on be nothing turn it off and back on and have power but not enough to start it after driving it for awhile….anyone experience this before
Remove screws and disassemble the plastic steering column halves
Disconnect the ignition switch wiring harness and inspect for grey oxidized clips or pins.
Verify the harness wiring or harness connector is not melted.
I just took it all apart everything looks fine i ordered a new switch see if its that
Inspect both battery cables to see if the insulation is shrinking away from the battery terminal clamp/terminals OR if there is a white or green substance mixed in the strands of battery cable.
The white or greenish substance can cause extra resistance in the wiring especially when the engine compartment is hot from previous operation.
This would indicate it is time to replace the battery cables.
Sometimes after turning the jeep off it will click like it has no power boost.
it its fine then other times turn the key no power.
dash acts up-- speedometer and rpm needles spazz out.
turn key off and back on be nothing / turn it off and back on and have power but not enough to start it after driving it for awhile.
….anyone experience this before?
I tried to make this a little easier to read just in case anybody here speaks English.
Sometimes after turning the jeep off it will click like it has no power.
Boost it,its fine then other times turn the key no power.
There ill fix it for you since ya cant read lol
Sounds like you have a phantom draw... something pulling down your battery.
Do you have access to an amp meter or clamping amp meter?
-Mac
-Mac
Seems alot more of a short somewhere then a phantom draw tho i ran it every day this week with no trouble then just randomly happened twice and seemed worst then before i changed the battery….batterys been charged and load tested before i put it in
Reactions: macleanflood
Well i parked the jeep after a 20 minute drive it was dead again never touched it for 2 days went out today fired up again
I changed the alternator today was still shorting out so i cut the battery cables hooked them back up to the terminals tried it and it fired up a couple times no troubles then it went back to the way it was so i made a cut in the cable halfway down and it was all corroded inside the cable itself 🤷‍♂️
