Hello everyone. I have a problem of which I cannot find a reasonable explanation. I acquired a 2005 Wrangler with 214,000 miles and a 2.4L engine. It came to me with a blown head gasket and I thought I could replace that, along with the timing belt and water pump, and get it back on the road. Disclaimer: I am retired from the white collar world and therefore not a certified mechanic, but I feel capable to fix most things on my Jeeps.
The previous owner admitted it overheated when the head gasket blew but I didn’t ask how hot it got or how long he ran the engine in the overheated condition. When I did my diagnosis, it was evident coolant got into the oil. I performed a compression test and cylinders 1 and 4 showed approximately 180 PSI while 2 and 3 were 130 PSI. I should note this was a wet test.
When I disassembled the engine, the head measured out of spec for flatness so I sent it to the machine shop to be milled. I was also careful to loosen the head bolts in reverse sequence of the torque pattern and loosen them a quarter turn at a time until I could remove them by hand.
Upon reassembly, the engine had zero compression. I took everything apart again and discovered with the head fully assembled with rockers, lifters, and cams, I could fit a .010 feeler gauge between several of the valves and seats, regardless of the position of the cams. When I removed just the cams and inverted the head, the combustion chamber would hold rubbing alcohol for a reasonable amount of time. Installing the cams would inexplicably not allow the valves to seat. I had the cams properly oriented (intake to the intake side and exhaust to the exhaust side) but for the life of me, I cannot determine why installing the cams creates this condition.
Any advice, besides never mess with a 2.4 Jeep engine again? Thanks.
