Intermediate Radiator Leak
Pat1998
Charleston SC
98 Jeep Wrangler. After starting up I am having a decent amount of coolant leak from the bottom housing of the radiator. Will drip steadily for 5-10 minutes and then stops all entirely with no more leaks. Seems to only occur starting up after sitting for a couple days.
No visible leaks/ cracks in radiator from what I can see.
Cool story?
I had a radiator that would also leak a small amount every so often. A few drops. Ran it for many years. Replaced it and no more leaks. When I replaced the radiator I did everything. Hoses, water pump, thermostat, the whole shabang. Shortly after I also had to replace the heater core. Buckle up.
Pretty common. The tanks are sealed with a rubber o-ring that lose elasticity over time. When that happens, it will seep a bit until the radiator warms up and then stop when the heat swells it back to size.
Reactions: Gilaguy23
