How to mount roof rack to the rear of a TJ
coopers.
WA
I have been looking at custom fabricating a roof rack for my 2005 Jeep TJ, however I do not know where to mount it in the rear. in the front I am going to mount it to the windshield hinges, but in the rear I am struggling to find a good spot to mount it. I was thinking to the frame behind the tailgate a lot like the GOBI roof rack. are there any premade mounting brackets I can order or should I costume make this part as well.
My Garvin rack that I had mounted between the tub and frame at the body mount at both rear corners. Then it had 2 more bolts going through the tub into a backing plate further up. If you plan on switching tops dependent on weather or folding the soft top up and down, I would consider designing the rear mounting point to allow the rack to hinge like the Garvin setup.
I've also got said Garvin rack for sale if you want to skip the fabrication....
