babyjeep
I'm late to this party...
I've got a high idle problem (on a ZJ) as well which is how I found this thread.
OP mentioned he ordered a new IAC and the plunger seemed longer than the one on the original IAC. One thing I did not realize right away is that the IAC plunger can be manually adjusted. You can rotate it to shorten it, and you should rotate it so it matches the length of your original IAC. Once you install it and start your engine, the idle will be high again, but the PCM will adjust. It will take about a minute and you will see it slowly come down to around 700 RPMs and stay there.
I just joined so I could post this here. I hope it helps someone else.
Meanwhile, my high idle is back ... so perhaps I should not be posting "solutions" just yet![]()
(It appears we can't edit previous comments so I'm adding this update here. Hope it helps.)
Following up on my "high idle is back" comment ...
It appears temperature is important. This time I *warmed up the engine*, then shut it all down, removed IAC, and rotated it to just below 1 1/8" again. High idle seems to be resolved now.
