Gauge cluster not working
Tlmanuell
Josephine, Texas
So my gauge cluster is not working. It lights up and I have some warning lights (airbag, brake etc) but no RPMS, Speedometer, Odometer, fuel, oil, voltage, temp etc. I’ve checked all fuses and the connections and all seem fine. Here’s a video attached to show all I’ve done. I’m in desperate need of y’all’s help.
Since you’ve already checked the fuses and connections, here are a few more troubleshooting steps you might want to consider:
Ground Connections: Sometimes, gauge clusters can act up due to bad ground connections. Make sure all the ground wires related to the cluster and the Jeep's electrical system are clean and tightly connected.
Cluster Reset: Try disconnecting the battery for about 10-15 minutes. This can sometimes reset the electronics and get everything working again.
Instrument Cluster Check: If you have access to a diagnostic tool, see if there are any error codes related to the gauge cluster. This can help pinpoint the issue.
Wiring Issues: There could be a broken wire or a short in the harness leading to the gauge cluster. Inspect the wires for any signs of damage or wear.
Cluster Replacement: If all else fails, your gauge cluster itself may be faulty. It's not super common, but also not unheard of.
If I had to guess it's something wiring related.
Hopefully, one of these solutions will help you get your gauges back to normal. Good luck, and keep us updated on your progress!
