97 TJ, base model with four angry squirrels.
PO did what I believe to be either a 2” or 2.5” suspension lift.
Since owning it I’ve added a winch and mounting plate that has sadly added 100lbs to my front bumper.
I’m considering the possibility of adding a coil spacer up front to compensate for the added weight. We have a lot of roads with cross ditches to mitigate erosion and I find my reduced up-travel is causing me to bottom out on the bump stops more frequently.
Can’t remember the members name on here but he had the JKS adjustable coil spacer. A viable option but somewhat expensive due to shipping to Canada.
TL;DR - what size coil spacer would be appropriate to compensate for roughly 100lbs of winch + mounting plate.
