Front drive shaft u-joint
blackntan
NJ
Hey is this amount of play normal? It seems like the u joint is not the problem but I am not sure.
Unless I missed something that play is the pinion/ring gear and pretty much normal. If you question The U joints shake the DS back and forth. The caps will stay put, or should and the cross section will move in the caps.
Hey thanks for the response. Okay Yeah I believe the u joint is fine as when i applied force to it there was little to no play.
As GATORB8 responded above; do you have any symptoms that you are concerned with ?
While inspecting the front driveshaft pinion end U joint; do you see any rust particles where the trunion goes into the U joint cup ?
From what I can see in the video; the play in the front pinion appears to be normal unless you are getting vibrations when you are driving.
Reactions: GATORB8
