Fog Light Relay
Rich1961
Spring Creek Nevada
I have the common issue of my fog lights turning on on their own at times. So until I have the time to replace or repair the multi-function switch I removed the relay. When I removed the relay I found that one of the blades on the relay was bent over as you can see in the picture. Is this normal, or did a previous owner do this for some reason. It is pin 85 on the relay.
82803
Rich
That was done by someone previously to allow your fogs to stay on with your high beams on.
Reactions: jjvw
