Slaverson Member Original poster Joined Feb 23, 2021 Messages 60 Location Park City, Utah Feb 25, 2022 #1 Got my flywheel off but I’m not too sure if it’s still good to use. I gave it a little sanding then ran out of brake cleaner. How does it look so far?
L J lights before loKCers Supporting Member Joined Nov 26, 2017 Messages 6,810 Location 🤡🌎 Feb 25, 2022 #2 IMO ... as long as there's no cracks ... MOAR sanding. I hit mine with an electric DA and some Mirka 60 grit that I had on hand. Reactions: Slaverson
CharlesHS TJ Guru Supporting Member Lifetime Supporting Member Joined Mar 10, 2020 Messages 6,387 Location Jacksonville FL, Quezon Philippines Feb 25, 2022 #3 The surface of the flywheel is slightly crowned; taking the flywheel to a machine shop to resurface is not advisable. IF you decide the flywheel needs to be replaced; Mopar is advisable, but LUK makes a good replacement. https://www.amazon.com/dp/B0049EDAQO/?tag=wranglerorg-20 https://www.amazon.com/dp/B000CICYZ4/?tag=wranglerorg-20 Reactions: Slaverson
