Flasher relay?
Noname
Canada
On the front driver side my signal isn’t working. Both when I turn on my headlights and when I turn my signal on, It only flashes quickly and only at the rear signal. My right passenger side it works fine.
The question i have is if it was the flasher relay would both of my signals be bad? I changed the bulb, the fuse is good. Trying to figure out if it’s either the wiring or the flasher relay. Those little relays go for 30-40$ which is shocking
Thanks for the help in advance
Need info. Jeep profile? LEDs added? Flasher model?
05 LJ. i jst took the bulb out, are led a bluish colour bulb? I just went with what the catalog recommended with the code but now Im realizing that it might actually be because of these led crap bulbs
That is a filament bulb with a blue gas to make it appear brighter. It is not an LED bulb.
Your relay is not bad. You have an electrical issue. Most likely a local ground or corrosion on the connector pins.
I have no clue what led light bulbs look like lol I only ever used normal type original. The blue glass confused me. Either way J swapped the passenger side with the driver and it fixed the issue? Weird. I think you’re right, electrical problem somewhere.
