OK, I'm a relative noob to the TJ, but I have a fairly good background in general automotive mechanics, so I'm not a complete moron...just a little incomplete
I'll start by apologizing for the length of the post, but in order to give you guys a full background of what's going on, it's necessary. 2003 TJ Rubicon with Auto Trans that I've only had for about a year now. 96K miles when I got it, about 104K now. Running just fine other than an occasional Check Engine light that was always intermittent and was caused by the TPS sensor voltage reading below acceptable range. This only happened very rarely and ALWAYS when I was idling with my foot on the break waiting to pull out into traffic. Since it's time to renew my registration, I figured that I'd simply adjust the idle a slight bit higher, reset the CEL, and move on down the road. Problem #1. Idle adjustment is from the underside of the throttle body. In the process of trying to remove set screw and replace from the top (where any sane engineer would have placed it), the tiny little set screw was cross threaded and refused to go back in. Phone call to 4 Wheel Parts and I have the upgraded BBK throttle body on the way. Upon receipt of said TB, I go to remove the remaining factory sensors from the stock TB and the TPS refuses to budge (previous owner/mechanic must have used loc-tite or something). Another trip to auto parts store and hardware store for new TPS and some machine screws to mount it. Finally get everything back together, start the TJ and the engine is basically bouncing off the rev limiter! WTF! I didn't have a high idle problem before, so what gives? I've had this thing in the warehouse at my office for nearly a week so any advise or ideas would be much appreciated.
JB
JB
