Here is my trans cooler set up.
When the summer days are 115 - 120 I need to keep the trans cool.
I used Two Derale frame rail cooler and the Derale 20561 cooler with fan.
Along with a remote filter that allows me to change a quart of ATF during every oil change.
I routed the line from the radiator cooler out to the dual frame rait. They are split so that each one is feed hot ATF.
This allows better cooling than just running it thru both coolers tied to gether.
The ATF is slowed down and has more time in each cooler dissipating more heat.
From the dual cooler it goes to the 20561 frame mounted Atf cooler with fan.
When the ATF exits the 20561 it is routed to the spin on filter then back to trans.
I have a 185 on off switch hooked to a relay to turn fan on and off, also have a switch to override the filter mounted swith.
When the 20561 fan is on I installed a green light that comes on to show me it is running.
When driving on the hiway the on 120 degree days it never comes on.
Offroading at during the 110 plus days ( I do not offroad in the extreme heat days) slow speed it will comes and runs briefly and shuts off.
It will cycle but not stay continuosly on.
