Since before I put an AGM battery in my 2000 TJ, I was only getting about 12.5v of charging after the engine warmed up. With the AGM battery, this is not enough voltages to keep the battery healthy. I tried plugging in a HP Tuners MPVI3 and upping the voltage in the program, but the option was not there for mine. This morning while moving my TJ around in the driveway, I saw 13.5v on the Torque app running on my radio. That is the highest volts I've ever seen on it. It was 31*F this morning. I'm assuming that the battery temp had something to do with the extra voltage. I do have the factory battery temp sensor.
In searching, I found these kits that are an external adjustable voltage regulator. Has anyone installed on or something similar?
https://alternatorparts.com/external-voltage-regulator-high-output-alternator-kit.html
