Engine squeal
RAC02
Jacksonville
My 2000 wrangler 2.5 makes this load squeal when I turn on the ac. Only the compressor though. I have already changed the ac clutch and bearing which didn't fix it. I read some say this is a tension issue on the belt and even one said this could be from the distributor assembly. Any advice? Thanks
mine had this issue After I did a thermostat replacement. I found out coolant/antifreeze isn’t good to get on the belt. Only made the noise when the A/c was turned on. I tightened and loosened the old belt and it never stopped, so I replaced the belt and haven’t heard it since.
Reactions: Hopper
So I guess in your case the belt was slipping. I wonder if the 2.5L TJ has a auto belt tensioner or manual. I believe it is manual. But not sure.
It might be worth replacing the belt depending on how it looks and when the last time it was changed was.
Reactions: Babygools99
x2 to what Chris said. You can also get a belt that bypasses the AC compressor just to help diagnose if its an issue with the AC or another component.
