Hey guys,
I occasionally have an engine sputter. It happens seemingly randomly and lasts for a fraction of a second. My RPMs will drop, engine light flashes, and it goes right back to normal as if nothing happened. I changed my CPS and now it doesn't seem to happen as often but it still does. Just the other night I found I can duplicate the effect on demand. When I flip my high beams on it sputters and the engine light flashes and it goes right back to normal. I do have the headlight mod folks recommend, Hella housings with the %130 (whatever the number may be I forget off hand) Phillips bulbs, and the accompanying harness. Everything works fine but I'm wondering if it may be a battery draw issue. I'm running a good yellow top Optima.
Now I'm feeling like it may have always been a battery issue, maybe an accessory like AC was kicking on and pulling too much current for a sec causing the intermittent issue. Am I thinking clearly here?
I appreciate it fellers!
