I got the PCM back today. The WranglerFix guys couldn't recreate the issues though I appreciate you fellas for the help!
With that ruled out I tested my ignition switch, plug, and harness today and it's also fine. I swapped the crank sensor years ago with no change. I'm going to check the opda and cam sensor tomorrow. Back in 2020 I switched to the crown unit and kept the Mopar sensor and I'm wondering if it's on its way out finally. I have the crown cps I could try but idk if my cam and crank are in tight enough relation for it to work without throwing a code and I don't have a thinkdiag or DBR to adjust it. I assume if I throw it in with the vehicle already up to op temp that I can tell if the issue is still present or not before it throws a code.
I'll report back.
I'll report back.
