I made a manometer to measure this on my XJ. Just need some clear tubing, a little water, and go for a drive. Then apply math.
Highway speeds where good for .036 psi. I estimated that'd be about 1/2 hp. Decided it wasn't worth messing with.
Pics are lost and I'm going from memory, but I would have tested cowl pressure vs. stock intake location, which on the XJ is behind the grill right next to the radiator. That's a high-pressure area too, and better than just under the hood like the stock TJ. It'd be worth testing as it should give better improvement than on the XJ.
I'd do it myself at some point but it's a low priority right now. If anyone is interested I'll walk you threw it. Should only need $5-10 of clear soft tubing from the hardware store.
