Dumb automatic transmission question...
Zorba
"The Veiled Male"
Lifetime Supporting Member
Merritt Island, Fl
... Just in general. Does an automatic transmission continue to pump fluid through the transmission cooler when in neutral?
As much as I know, yes.
Same here. The ones I am familiar with (GM Turbo Hydramatics) have a front pump driven by the torque converter, so as long as the converter is turning the pump is pumping.
I can also attest to this by the amount of transmission fluid I sprayed all over the place when I started the engine with a cooler line disconnected.
