Finally I will be replacing the ball joints on my 05-LJ and wondered if I have to open the Diff to get the axle out?
Yes, it's the same for the Dana 44 too... no need to open the front differential to remove its axle shafts. That's only required with the rear c-clip Dana 35 axle or other c-clip axles like the Ford 8.8.No. When you remove the axle hub assembly, the axle pulls out freely. It's not c-clipped like the Dana 35's.
(this is for the Dana 30; if you have a Dana 44 instead, I'd imagine that it's the same)
A good reason to open the diff at the same time would be to replace the inner axle seals. You would already be most of the way into that job.
If you are doing ball joints I would go ahead and replace hubs/wheel bearings while its all apart.
Are those pretty straight forward?A good reason to open the diff at the same time would be to replace the inner axle seals. You would already be most of the way into that job.
"while you're there"
I recall using a pipe and a large socket to push the seals into place.
... That said, it was just yesterday evening when someone told me that a 36mm axle-nut socket is just about the perfect size for pressing the seals in from the outer ends of the tubes; I can't verify that fact, but I can verify the fact that I know where that guy lives should his info turn out to be bogus and thereby earn him a pummeling.
Since the 36mm was by far the largest socket I owned at the time, I suspect that was the one I used.
I take it this is what you're referring to?There's a nifty little specialty-dingus that pushes both of them right in at the same time with no muss or fuss; it's about $135, but that's actually pretty cheap for tools from the specialty-dingus world. That said, it was just yesterday evening when someone told me that a 36mm axle-nut socket is just about the perfect size for pressing the seals in from the outer ends of the tubes; I can't verify that fact, but I can verify the fact that I know where that guy lives should his info turn out to be bogus and thereby earn him a pummeling.
I'd only replace the inner seals if the carrier is going to be out anyway which it won't be in this case. If you're not getting gear lube leakage out of the outer ends of the axle tubes you're good. It's only a straight-forward job if you've done it before and have the right tools.Are those pretty straight forward?
I wouldn't assume anyone's gears would be fine using synthetic inside the diff. Not since it was learned that the gears run hotter with a synthetic gear lube. Hot enough to do damage? Maybe, maybe not. But it was hot enough to damage my new gears last year after filling the axles with synthetic after getting talked into it against my better judgement.Assuming that your gear setup is fine with full synthetic.
