Curious if anyone has done this here.
https://www.cherokeeforum.com/f67/17-diy-big-brake-kit-xj-mj-tj-yj-Dana 30-44-a-222937/
https://www.cherokeeforum.com/f67/15-diy-big-brake-kit-xj-mj-tj-yj-Dana 30-Dana 44-227121/
http://jeepm62superchargerkit.blogspot.com/p/blog-page.html
https://www.rme4x4.com/threads/better-brakes-for-the-lj.116389/
Above are links to the most useful links to this as well as an attached pdf. Some info is a little repetitive but there is plenty of good info.
My LJ is mostly stock except OME 2-2.5" springs, 33" tires on 17" JK wheels. The braking performance certainly leaves a lot to be desired. While I could order a Vanco or similar, it seems saving $1000 or more would be worth the slight hassle.
Any thoughts?
Any thoughts?
